| crank dampner help! https://slantsix.org/forum/viewtopic.php?t=44819 |
| Author: | Turbo Toad [ Mon May 02, 2011 8:51 pm ] |
| Post subject: | crank dampner help! |
Here's my dilemma I was trying to remove my crank dampner with a two jaw puller and I pulled the pulley off the dampner Is there a way to press the pulley back on or should I try and replace the dampner with a new one? also there is a rubber ring between the dampner and the pulley I think that would need to be replaced as will does anybody have any ideas were I can get a new one? Does anybody make a after market dampner? The motor is a 69 motor Aaron |
| Author: | 61 V200 [ Mon May 02, 2011 9:00 pm ] |
Do a search on this site. I know there are several companies that can recondition the one you have or sell you a new one. As far as I know it is not something you can do in your garage. |
| Author: | Turbo Toad [ Mon May 02, 2011 9:19 pm ] |
Quote: Do a search on this site. I know there are several companies that can recondition the one you have or sell you a new one. As far as I know it is not something you can do in your garage.
I did do a search before I posted and I couldn't find any info Thanks Aaron Maybe Charlie or slantsixdan will chime in Thanks .org for all your help!!!!!!!!! |
| Author: | 61 V200 [ Mon May 02, 2011 9:26 pm ] |
Here and Here |
| Author: | Joshie225 [ Mon May 02, 2011 9:55 pm ] |
| Post subject: | Re: crank dampner help! |
Quote: Here's my dilemma I was trying to remove my crank dampner with a two jaw puller and I pulled the pulley off the dampner
Bummer. Next time use the threaded holes in the damper hub. Quote: Is there a way to press the pulley back on or should I try and replace the dampner with a new one?
You can't just press it back together, but it can be rebuilt. I like the Powerbond new ones myself.
| Author: | Turbo Toad [ Mon May 02, 2011 10:48 pm ] |
Quote: Quote: Here's my dilemma I was trying to remove my crank dampner with a two jaw puller and I pulled the pulley off the dampner
You can't just press it back together, but it can be rebuilt. I like the Powerbond new ones myself.Do u no who carries the powerbond models? Thanks Aaron |
| Author: | Pierre [ Tue May 03, 2011 12:51 am ] |
Here you go. |
