| broken t-case...weird? https://slantsix.org/forum/viewtopic.php?t=44824 |
| Author: | 4x4jimbo [ Tue May 03, 2011 9:47 am ] |
| Post subject: | broken t-case...weird? |
so i decided to try my 4x4 again after it failed on my this winter ...in a snowbank.what was happening was whenever i put it in 4 wheel low or high'' it would get stuck and not move.so i tried it again yesterday ..same thing. so i pulled the inspection plate for the front wheel drive gear ,whata ya know the chains chewed to peices.never had this ,especialy with these old t cases its a 1976 np 203 i beleive.its in my 4x4 conversion van with a 727 and slant 6.WHAT CAUSED THIS ???? i have a replacement already but thought it was weir? jimbo |
| Author: | sandy in BC [ Tue May 03, 2011 2:36 pm ] |
Thats is very common for the NP203. The chain wads up and takes out all the monkey motion. They are a full time TC with a "differential" between shafts. If you can.... replace it with a NP 208....lose 100 lbs....gain the ability to run 2wd. NP 203 is my least favourite TC.......... |
