| 904 neutral grinding https://slantsix.org/forum/viewtopic.php?t=44840 |
| Author: | Nongan [ Wed May 04, 2011 8:46 pm ] |
| Post subject: | 904 neutral grinding |
Ok, I ran a search and couldn't find this question. When I go from reverse to neutral or drive to neutral, it grinds either until I shift out sometimes but most of the time it's only for a second or two. Please help! 904 column shift |
| Author: | THOR [ Thu May 05, 2011 8:15 am ] |
The only thing I can think of that would grind inside the trans would be the park pawl. Are you moving when you shift or completely stopped? ~RDE~ |
| Author: | slantzilla [ Thu May 05, 2011 3:11 pm ] |
If it's grinding shifting into neutral you have a clutch pack/bushing eating itself. Pull the pan and see what's laying in it. |
| Author: | Nongan [ Thu May 05, 2011 8:51 pm ] |
Alright will do, also going from reverse to park causes this too |
| Author: | Nongan [ Thu May 12, 2011 9:15 pm ] |
I think I figured this out, the starter isn't disengaging all the way sometimes so it grinds when i change from reverse/drive to neutral |
