It is currently Mon Nov 23, 2026 12:25 am
PostPosted: Thu Apr 21, 2011 9:42 am
I bought a 1966 dart wagon with a 3 speed column shift. Some detective work informs me the engine is from 1970. It was a pig in a poke as it wasn't running right. A new fuel pump and a carburetor rebuild later (and and and..) I got it running right. I hopped in to take a spin but I discovered. I have to really ride the clutch and rev high to get first gear to engage. Once it starts moving I get a fierce shutter and it really wants to go fast. If I'm on level ground it is much easier to start moving in second gear. Once it's moving it's a dream. I can shift back and forth between 2nd and third, no problem. Starting in reverse is alright. My friend convinced me it could be sloppy linkage. We worked on that. Although the shift selector now feels wonderful, the first gear engagement problem hasn't changed.
I'm sure this has been addressed somewhere else on the forum but I couldn't find it. Any help is very appreciated.
I'm pleased with myself for giving a damn.
PostPosted: Thu Apr 21, 2011 10:47 am
6 Pack Dart
Sugest you adjust clutch, don't know how as mine are automatics. But it sounds like that from your description.
Richard
PostPosted: Thu Apr 21, 2011 10:49 am
Not getting into first gear:
Incorrect adjustment of 1st-Rev. shift rod; improper cross-over adjustment; incorrect adjustment of clutch; or bent parts…
First & reverse gear are not synchronized in this transmission. Any movement of car, and letting out clutch in first gear at or above idle before it is fully engaged will cause a lot of grinding.
Shuttering of clutch can be caused by contaminated surfaces, maladjustment, worn out clutch surface, and or warped clutch plate. Starting off in second gear will cause a shuttering, and third a stall.
One shouldn’t have to ride the clutch, or rev the engine to make a smooth take-off in first gear.
If I had to guess, I suspect that your clutch is burnt, and transmission levers & shift linkage are not adjusted correctly. Make adjustments to linkage per factory service manual, than assess condition of clutch once the transmission can be properly shifted into all gears without difficulty.
Also inspect tightness of bolts attaching transmission & bell housing to engine, make sure they are properly torqued down [50 foot pounds]
PostPosted: Thu Apr 21, 2011 12:30 pm
Thanks gang. Amazon assures me my shop manual is in the mail. The idea that it could be linkage adjustment is very comforting. I know I also need to change the gear oil.
I was planning on digging into it on Saturday, but somehow a big weekend snuck up on me. I don't know why I have to go visit the family. My mother has already had 74 birthdays before and how many Easters have there already been? Lol.
PostPosted: Thu Apr 21, 2011 1:15 pm
[quote]My mother has already had 74 birthdays before and how many Easters have there already been?[/quote]
About 1979 or so, give or take.
If you know what’s good for yeah, be a good lad and go see your mother. No back talk… LOL
Wait till she is 88…like my mother.
That old transmission will still be screwed up next week, you won’t miss a thing. Plus that FSM will be delivered by than...
PostPosted: Thu Apr 21, 2011 1:36 pm
And for a "Plan B" ... start saving your lunch money and think about swapping the car over to an 833 Mopar 4-speed or to the 904 automatic trans.
The early "3-on-the-tree" set-up not very strong and a PITA to drive.
Just my 2 cents...
PostPosted: Thu Apr 21, 2011 2:08 pm
That's some good advice. My mom was a public school teacher for 30+ years She can shrink a grown man to an infant with a look.
One thing I did not expect with the 3 on the tree was that the shifter would rest on my leg in 1st and 3rd gears. Granted I'm a big guy(6'5" all limbs), I don't fit in cars as a rule. But that was a surprise. I'll look into an eventual swap. I'm sure there is a thread already but, what years are compatible? Are there pitfalls to avoid? Well, I should do a search before I expect a reply
PostPosted: Thu Apr 21, 2011 4:13 pm
What's your "pleasure"...
Do you want to keep the car manual shift or do you like automatics?
Both swaps are pretty easy but going to the auto trans is likely a little cheaper & faster. (no floor cutting & welding)
PostPosted: Thu Apr 21, 2011 6:29 pm
hey grandmother will be 102 this coming may 4 th...retired grade school teacher also....go see MOM ,spend easter with her... check clutch adjustment and shift adjustment too ...if still chattering....new clutch,pressure plate and throwout bearing....wouldnt hurt to get flywheel resurfaced...can put three on floor ar get 4 speed w/wo overdrive
keep on roddin'
PostPosted: Sat Apr 23, 2011 5:26 pm
Here's a silly question, are you sure that you are actually in 1st gear (when you think you are)? I mean when I read your post; you have to rev it, slip the clutch, it shudders AND REALLY WANTS TO GO FAST, that sounds like 2nd or 3rd gear. Have you driven a 3 on the tree before?
Another thought, maybe someone got the shift linkage together wrong, (you can attach the levers upside down on the trans if you try)
63 Valiant Wagon
225 - 4 bbl
PostPosted: Sat Apr 23, 2011 11:23 pm
WrC yeah I thought of that. As I was rebushing the linkage under the watchful eye of someone smarter than me he assured me that it was not the case. He pointed out that there are no syncros to shift down to first. So my Sherlock deduction is that first really is first.
PostPosted: Sun Apr 24, 2011 12:26 pm
I can tell you from past experience that all you are going to get out of first gear is about 40 mph if you had a 273, and 3.24 rear with 13 “ tires, and go peddle planted hard to the floor. I suspect a stock slant would be a bit less, as it won’t turn up as fast as a V8.
First gear take off is rather easy on the rigging, and really wants to be shifted at about 15 -20 mph.
I now suspect that you are trying to pull off from a stop in third gear, and not engaging the “Râ€￾-“1stâ€￾ side of the “Hâ€￾ shift pattern.
You said that the shift lever is resting on your leg in top gear. This indicates that your linkage needs to be adjusted at a minimum or new bushings installed as the gear lever shouldn’t be riding so low.
My old Dart had real sloppy shift levers, and the lever could be rotated all the way over to the left side of the steering column missing R & 2, and on to one’s leg on the right passing first and 3ed. It took a bit of English on the lever to get it to the proper gear.
Have someone under the car (secure it with wheel chocks, engine off) viewing the shift levers on the transmission as you shift from {R-1} “Nâ€￾ {2-3} and back through the “Hâ€￾ pattern.
Few people still driving these days have ever operated a column shift manual transmission. They fell out of favor by the mid sixties, as floor shifted transmissions, and column shifted automatics became the rage.
The following is a tutorial on operating a column shifted “Hâ€￾ pattern three speed transmission. Something is amiss, and without sitting next to you, or trying the car my self, I need to cover all possibilities. So don’t take this the wrong way…
With three on the tree, move shift lever mid way between top & bottom of “Hâ€￾ pattern to where the cross is located in the “Hâ€￾. This “mid-wayâ€￾ area is “Nâ€￾. The shift lever will want to settle to the {2-3} side of the “Hâ€￾ (closest to dash board) on its own. You will need to pull the lever in the direction of the steering wheel or in other words towards you a few inches, to cross over to the front section {“Râ€￾-“1â€￾} side of the “Hâ€￾.
So shifting from 2 to 1(car must be fully stopped, no syncro in first) you rotate lever down half way than gently pull the lever toward the wheel an inch or two, and rotate down by your leg to engage first. To go from first to second: rotate lever up, relax grip letting lever slide forward along “Nâ€￾, than swing up to second gear. Second to third gear is just a genital full swing down to third. No hunting for “Nâ€￾, just one smooth ark down to third.
Remember first & reverse are not synchronized, and any time one shifts into these gears, the car must be stopped dead, no movement, or there will be grinding of gears.
PostPosted: Mon Apr 25, 2011 11:14 pm
Thanks Fellas. I wish I could blame this one on operator error. I do know the fine subtitles of driving a stick shift. It took only one call to my older brother to remind me what my dad taught me back in the early seventies. I'd have been very glad to be wrong.
If I can drag my weary bones out of bed early enough I'm going to futz with adjusting the linkage before work.
PostPosted: Tue Apr 26, 2011 7:35 am
Just from reading all the posts, adjustments of linkage isn't the main problem, although the slop in the linkages needs addressing, the driveability issue I would fix first. Out of adjustment clutch, or worn out clutch disc/pressure plate as stated above. I would get the car mobile in a proper fashion first then worry about the lever position IMHO...
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Tue May 03, 2011 2:05 pm
I got to do some wrenching this weekend. The clutch was just about perfect. Took some slop out of the linkage. Voilà! I drive it to work today. My job site is at the top of the berkeley hills. The wagon did not complain a bit. Due to my stork like figure I will be shopping for a smaller steering wheel. It was also pointed out to me that the shifter lever is longer than stock. That's part a big part of it crowding my 40 inch inseam. Boohoo, right? It's like getting leaves in my swimming pool. Thanks for the help everybody. Now to address the mysterious brake light. But that's for next weekend.
