It is currently Wed Jun 17, 2026 8:25 pm
 Post subject: engine id
PostPosted: Thu May 12, 2011 10:20 am
I have just bought a car that had a slant six out into it. i can not see the engine number and there is no id marks that i can see to tell me what they model is or what the year is. can anyone give info as to how i can id the motor, only thing i know is that it has a one barrel carb
This account is used for member help ONLY!
PostPosted: Thu May 12, 2011 2:36 pm
Several spots to look for casting & other [url=http://www.mymopar.com/index.php?pid=31] numbers[/url] are:
Above freeze plugs on left side of block
On top of machined surface of block protruding out from under head below plug # one behind alternator.
Under valve cover between valve springs and driver’s side of head.
Transmission & rear-end will have numbers stamped and or cast on them as well.
Additionally one can tell if engine is a 170cid. by measuring short coolant hose between water pump & head. If it is about 1" it's a 170cid., if it is about 3" it could be either 198cid. or 225cid.
This thread should be moved to “Otherâ€￾
 Post subject: found engine number
PostPosted: Fri May 13, 2011 11:49 am
i found the engine number, it is 28107188 does that give me any info on the engine type or year of the engine anything else tnx
PostPosted: Fri May 13, 2011 12:54 pm
6 Pack Dart
"On top of machined surface of block protruding out from under head below plug # one behind alternator"
The numbers will be hard to find, clean the dirty goo off and you should be able to read them.
Richard
PostPosted: Fri May 13, 2011 1:07 pm
Compare the block casting numbers to the numbers found HERE.
PostPosted: Fri May 13, 2011 2:17 pm
Me quoting me:
Several spots to look for casting & other numbers are:
Click on red words for a hot link to more information. In this case it will take you to a Mopar decoding site.
Users browsing this forum: Ahrefs [Bot] and 9 guests
