It is currently Sat Jan 03, 2026 8:53 pm
 Post subject: valves
PostPosted: Wed Dec 14, 2005 6:54 pm
is there a stock replacement for bigger valaves in some type of cars that will go into a 225 head 1974 model. i have heard about some of you using ford valves.
i dont really want to order valves because my machinest gets deal if i can get a stocker replacer.
thanks guys, yall are awesome, dustin
PostPosted: Wed Dec 14, 2005 7:08 pm
I believe 302 ford valves should be the same length (or nearly), but you'll have to have the valve guides replaced w/ 11/32 guides instead of 3/8. Not a big deal if you're having them done anyway. I think there are also some SB Chevy valves that will fit. (again 11/32) Just keep in mind that stock sizes for /6 are 1.36 and 1.62. Looking at it, you should have around .10 to .15 to play with on each.
PostPosted: Wed Dec 14, 2005 7:21 pm
thank you very much
will post pics as soon as i get this beast built
goin for 200 horses!!!!
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 17 guests
