It is currently Mon Nov 23, 2026 12:56 pm
 Post subject: 833 t0 904t
PostPosted: Tue May 24, 2011 6:09 am
Having now gone thru three 833 trannys in my '83 D-150, I need to go to a 904t, so I can spend some time driving my truck instead of working on it.
Any suggestions caveats or just bad ju-ju to look out for, any good reasons to stay with the 833? I would like to use a floor shifter so to not have to replace the steering column also what to look for here?
thanks
robert
 Post subject: .
PostPosted: Tue May 24, 2011 2:31 pm
Are you towing trailers or heavy loads all the time? I can't imagine breaking three 833s unless they were all 300,000 mile junk yard units. I beleive a 904 is marginal for a heavy truck or van-even a S/6,and a 727 would be better.
 Post subject: Keep 833
PostPosted: Tue May 24, 2011 7:22 pm
The 833 is plenty strong, and like bigslant6fan said something else may be going on. What is breaking on them? Are they the aluminum case or cast iron.
The 833 gives you and extra gear over the auto and it is overdrive. Better gas mileage...etc.
Rick
