It is currently Mon Nov 23, 2026 12:00 pm
 Post subject: 8 3/4 rebuild
PostPosted: Tue May 10, 2011 2:29 pm
i'm rebuilding my 8.75 rear in my 68 dodge A100 and i wondered what vendor you folks use... i saw complete master rebuild kits on ebay from various sources including one called nitro... are they of descent quality? it'll be a stock rebuild behind a stock 225 and 727 i just want to do it once and not think about it for another 40 years so i want the good stuff... thanks in advance...
PostPosted: Wed May 11, 2011 8:47 am
I have never seen much difference with the contents of these kits so shop around a find one at a reasonable cost.
(the biggest difference I usually see is the price and the packaging! :roll: )
PostPosted: Wed May 11, 2011 11:43 am
thanks... so there is no major difference in the bearing and seal quality of the different brands then?
PostPosted: Tue May 17, 2011 4:56 am
I've always tried to use Timken bearings in my 8 3/4's. I've been fine with CR, National, etc seals.
PostPosted: Sat May 21, 2011 7:49 am
Im not sure if it makes a big difference or not but I went with the green bearings and havent had any problems with it (so far) in the last 6 years.
PostPosted: Sat May 21, 2011 10:18 am
thanks folks...
