| Arp Main Stud Help https://slantsix.org/forum/viewtopic.php?t=45003 |
| Author: | Turbo Toad [ Tue May 17, 2011 5:11 pm ] |
| Post subject: | Arp Main Stud Help |
Ok I was installing my ARP main studs today and I ran into a problem on the rear most main I installed the studs but when I put the oil pan on to check for clearance the end studs were about a 3/8 to tall My solution I'm thinking about chasing the threads with a tap but I'm not sure is there a oil galley beneath the studs or is it safe to run a tap down the threads? The only reason I'm asking is there was a lot of oil on the threads when I removed the main bolts I don't want to have to alter the new MAIN STUDS any so if anybody has a solution or has gone thru this before please let me no Aaron |
| Author: | ceej [ Tue May 17, 2011 5:17 pm ] |
The Main studs come pretty close to the pan. If you trial fit it without the rear pan seal, it touches. Was that the case? Try using something like the old rear pan seal in place over the rear main seal retainer. It holds the pan up quite a bit. The car pan for the 70's A-Bodies fit fine. I'm not certain about other pan varieties. CJ |
| Author: | Turbo Toad [ Tue May 17, 2011 6:29 pm ] |
This is a early a body pan the the rear of the pan doesn't even touch the base of the block its raised up about 3/8 if a inch Were the pan tapers around the rear main seal is where the main studs are hitting the base of the pan Aaron |
| Author: | Turbo Toad [ Wed May 18, 2011 4:43 pm ] |
I chased the threads out this morning and reinstall the main studs and got the clearance that I needed Thanks Aaron |
| Author: | bigslant6fan [ Wed May 18, 2011 5:07 pm ] |
| Post subject: | / |
There IS an oil passage feeding the main bearings,that crosses through the tops of the main bolt holes. If you thread a longer main bolt too deep,it can block oil supply to the crank. I remember Doug Dutra "Doc" had a post on this long ago, it might be a good idea to ask him. |
| Author: | stop the beast [ Tue Jan 10, 2012 10:29 am ] |
Quote: I chased the threads out this morning and reinstall the main studs and got the clearance that I needed
Hey Toad,Thanks Aaron Do you know if this ARP main stud issue is prevailent with the early A oil pans? I was considering a set but A) I'm not sure they are needed over stock and B) I don't want to chase the threads down further. What do you think? Do the mains have any issue on the /6? On all my other tubro builds I've used stock mains and ARP head studs. |
| Author: | terrylittlejohn [ Tue Jan 10, 2012 11:42 am ] |
just cut the bottom treads off the one on the oil supply side to make sure it`s not going to deep. |
| Author: | Greg Ondayko [ Tue Jan 10, 2012 11:50 am ] |
Quote: just cut the bottom treads off the one on the oil supply side to make sure it`s not going to deep.
I like that idea.. Greg |
| Author: | Doc [ Tue Jan 10, 2012 1:42 pm ] |
Be sure to check the oil passageways leading down to the mains to be sure there is no obstruction. Install the studs and use a long drill, to be sure there is no blockage. Cut or grind-off the end(s) of the stud(s) if needed. DD ![]()
| Author: | Volare4life [ Sat Jan 14, 2012 4:34 pm ] |
and if i were you I would use one of the old bolts, stick it in the main cap in question and measure how much stick out and compare that to how much is threaded on the ARP studs, -Mike |
