It is currently Thu Jun 18, 2026 12:51 am
PostPosted: Tue Feb 07, 2006 10:38 am
Car Model: A couple slant six mopars and other mopars
What is the best to use on a daily driver VS. race, a vented distributor cap or un-vented.
PostPosted: Tue Feb 07, 2006 10:41 am
Use a Standard-Bluestreak CH-410X. It is vented.
PostPosted: Tue Feb 07, 2006 1:37 pm
I believe vented caps are required on electronic ignitions.
I haven't even seen a vented cap for sale for years.
aed
/6>V8
PostPosted: Tue Feb 07, 2006 1:47 pm
They're not required on any ignition. It's just that they are better at resisting internal flashover and condensation buildup.
?? Echlin, Standard, BlueStreak, Wells...
PostPosted: Wed Feb 08, 2006 7:49 am
thanks for the replys
I hope to get my slant running like better.
PostPosted: Wed Feb 08, 2006 10:00 am
Don't get an Echlen or Bosh. The rotor was melting the material around the contacts in the last Echlen I used, and a Bosh I got (never installed, returned it) had so much casting flash around the contacts they where partialy obscured. So I took Dans advice (yet again :wink: ) and got the CH-410 Standard cap.
On a side note, the place I found the cap was a local mom & pop store, and when I told the guy what I needed, he walked right to it on the shelf. No looking on the computer, no asking if the car has AC or front disk brakes, just the correct part. Its 7 miles out of my way, but he's getting my business now!
PostPosted: Sat May 14, 2011 8:49 am
Sorry so late for the reply.
I guess I should have said "needed" instead of required. As it was explained to me, the higher temps of the electronic ignition create higher pressures under the cap and need to be vented. It'll work with a non-vented cap, but they don't last as long.
I should have said *non* vented cap.
aed
/6>V8
PostPosted: Sat May 14, 2011 9:58 am
Those are still available, too.
PostPosted: Tue May 17, 2011 10:17 am
I got a blue streak cap, after a few Weeks my truck started running weird I took the cap off and the center point for the coil that contacts the rotor has broke off :shock: No idea why. My dad had gotten it for me along with a blue streak rotor. It was quite odd.
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 1 guest
