| Need a supplier of headlight bezel attachment screw bushings https://slantsix.org/forum/viewtopic.php?t=45040 |
| Author: | wjajr [ Fri May 20, 2011 3:59 pm ] |
| Post subject: | Need a supplier of headlight bezel attachment screw bushings |
I’m looking for the plastic bushing, for lack of a better term, that a trim screw would thread into to secure headlight bezels to my 1967 Dart as pictured below. I suspect that the same part was used on 68 & 69 models. In the photo below, one of the factory bushings is install in upper right of headlight. Lower right bushing is missing leaving a small square hole where one would be inserted. Previous owner had drilled sheet metal adjacent to bushing to receive a sheet metal screw. This method of attachment is not working out to well, as these holes are getting too large to hold a screw securely. ![]() Bill |
| Author: | 65Dodge100 [ Fri May 20, 2011 8:49 pm ] |
Little things like that are a bear to find. You have to match the screw hole size and the square hole size. Most body shops have a junk box full of things like that and can sort through and find something that will work. I'll try to find mine - it's been packed up for a while. If you can get a measurement of the square hole it would help. You might also find something like that in the "HELP" rack at NAPA but I assume you've already tried that. Danny |
| Author: | Nongan [ Fri May 20, 2011 10:33 pm ] |
Measure the holes and pm me, I have some for a '74 not sure it's the same size though |
| Author: | SlantSixDan [ Sat May 21, 2011 5:48 am ] |
At least one of the outfits listed here will have them. |
