It is currently Fri Jun 19, 2026 5:42 am
 Post subject: which axle is better?
PostPosted: Sat Nov 23, 2002 12:13 pm
I took out my passenger side rear axle. I turned the axle in my hand and the bearings felt perfectly smooth. The one I was going to put in also felt perfectly smooth, but it was stiffer than the one I took out. What I mean is that when I spun it around, it wouldn't go as far before stopping. Which axle should I put back in, the stiffer one or the looser one? Also, do I need to use axle grease?
 Post subject: 7 1/4 Axle Bearings
PostPosted: Sun Nov 24, 2002 11:26 am
With these bearings, "stiffer" is better. I base this on the fact that new ones are pretty tight & stiff when you get them.
These are sealed bearings and come "pre-lubed" so no extra grease is needed on the bearing but put a little grease on the seal surface.
