It is currently Tue Nov 24, 2026 8:06 am
PostPosted: Fri Jun 10, 2011 3:02 pm
is there any factory deep transmission pan made...interchange..looking for more capacity without the summit $200 price.
thanks
slant six's RULE!
http://www.usajon.com
PostPosted: Fri Jun 10, 2011 3:10 pm
The current-production pan is deeper than the ones that came standard when slant-6 vehicles were being built. Assuming you're building a 904, pan is p/n 52118 779AB, and they even include a spiffy magnet to catch metallic shavings. Also get the really nice double-seal, reusable rigid pan gasket P/N 4295 875AC.
PostPosted: Fri Jun 10, 2011 3:18 pm
any idea how much more capacity dan da man...
slant six's RULE!
PostPosted: Fri Jun 10, 2011 3:26 pm
There are aftermarket pans that are +2 quarts. Check here for both the MP stamped unit and cast ones. Good plus is the drain plug too. I second the nice gasket Dan mentioned.
PostPosted: Fri Jun 10, 2011 9:11 pm
looks like the stamp steel one is 1 quart
the cast aluminium is 2 quarts or larger..I found a TCI cast aluminum 2 quart unit for $83 delivered..anyone ever had issues with TCI ?
also on some jeep 4x4 forums they talk about installing a temp sending unit in the corner of the pan...is that just for 4x4 app. or do Drag racers do that too?
slant six's RULE!
PostPosted: Sat Jun 11, 2011 7:32 am
That is a steal for the TCI pan. Stock stamped ones I've seen give the same extra cap as TCI - 2 qts.
PostPosted: Sat Jun 11, 2011 10:12 am
One of the deep pans I have is a stock pan off an A-500 or some derivative thereof. IIRC, it's a truck pan.
PostPosted: Sun Jun 12, 2011 1:02 pm
looks like they pulled the eBay listing..
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AUS%3A1120
I have sent an email telling i wanted to buy, but they have not answered yet..
slant six's RULE!
PostPosted: Sun Jun 12, 2011 3:13 pm
I'm curious. What problem are you seeking to correct with the increased fluid capacity?
PostPosted: Sun Jun 12, 2011 3:28 pm
no problems
but I have always like extra capacity in the transmission for racing.
heat will kill an auto trans prematurely.
on hauling packages on trucks they have a trans cooler
and I do have a tow hitch..ha!
slant six's RULE!
PostPosted: Sun Jun 12, 2011 4:28 pm
I know about transmission coolers, but that's not what we're talking about. Two quarts more fluid will only slow the increase in fluid temperature slightly which is one reason why I was asking. Deep pans are really of best use when the fluid pickup becomes troublesome on high G launches.
PostPosted: Sun Jun 12, 2011 5:09 pm
well I do drag race more then drive on the street. I guess most deep pans were for OD trans/work vehicles/4x4's
I always ran a deeper pan for the strip..probably old sckool peeps influence me. here's some nice pans for various apps.
http://www.partshp.com/Pans.htm
slant six's RULE!
PostPosted: Sun Jun 12, 2011 7:29 pm
http://www.pacefabrication.net/services.html
should be an excellent source.
PostPosted: Wed Jun 15, 2011 4:41 am
The reason you see jeepers talking about the trans temp gauge install is kinda two fold. First, is the obvious. Slow crawling in 4WD can increase trans temps a bunch. Then there's the problem with the 42RLE in the new Wranglers that Chrysler does NOT want to address. A lot of these new Jeeps have burned. The cause has been narrowed down to trans fluid overheating, boiling out of the dipstick tube onto the exhaust manifold and causing a fire. The resulting fire takes out nearby fuel lines and the rest is history. I had an 08 Wrangler and one of the first things I did was install a hardlined cooler in line with the factory one. If you run an extra capacity pan, I would not think a fluid temp gauge would be necessary, but it couldn't hurt I suppose.
 Post subject: .
PostPosted: Wed Jun 15, 2011 11:39 am
While you got the pan off,check the line pressure adjustment. See my post on page 2 "shift kit,worth it?"
