Whats up with my rear end?
https://slantsix.org/forum/viewtopic.php?t=45099
Page 1 of 1
Author:  ESP47 [ Tue May 24, 2011 8:27 pm ]
Post subject:  Whats up with my rear end?
I have a 7 1/4" with 2.76 gears. About a month ago I started hearing a "whomp whomp whomp" when going above 15mph or so. Now the last week or so, when I corner quickly I can hear a not so good noise coming from the rear. It's like a louder whomp type of thud that goes on when I take tight right hand corners going semi quickly. I havent heard it when making left turns but I may have just not made as many quick left turns. I had my driver side rear wheel bearing done a few years ago. Think its the pass side bearing now or something else? I dont remember it sounding like this before when the other bearing was going out. I added oil to the rear but it didn't change anything.
Author:  emsvitil [ Tue May 24, 2011 8:51 pm ]
Could be a tire
Rotate them to inspect and see if the problems go up front.
Author:  ESP47 [ Fri Jun 03, 2011 9:16 am ]
Ok I just did that yesterday and it didn't change anything. I also inspected the brakes and they are fine.
I don't have one to compare it to right now so I'm just going to try and explain this, let me know if its normal. Like I said it's a 7 1/4" non sure grip rear. When I jack the rear end up and spin the rear wheels, it's like theres a little bit of free play. Like I can take the wheel and move it back and forth and there is a little bit of play and a slight knock inside the rear end when I do this. There is almost no play when I pull the wheels out away from the car, but when I spin them back and forth there is some play until I turn it far enough to where it catches. Is this normal?
Author:  Reed [ Fri Jun 03, 2011 9:37 am ]
I recommend pulling he inspection cover and seeing if you don't have a spider gear or two losing its teeth.
