Has anybody used a Hurst shifter on an A833OD transmission
https://slantsix.org/forum/viewtopic.php?t=45112
Page 1 of 1
Author:  Exner Geek [ Wed May 25, 2011 6:06 pm ]
Post subject:  Has anybody used a Hurst shifter on an A833OD transmission
I would like to hear from anyone who has used a Hurst shifter on an overdrive transmission in an A body. What pieces did you use? Where did you get them, etc. I have quite a few parts but have never really been able to make it work, would like to hear from someone who has.
Author:  Rick Covalt [ Wed May 25, 2011 6:21 pm ]
Post subject:  ?
Seymour,
That is what we put in Ryan's Swinger. I thought it was just a standard Competition Plus shifter and standard rods? What's in your Valiant now?
Rick
Author:  Joshie225 [ Wed May 25, 2011 6:50 pm ]
Every A833OD I've seen came with a Hurst shifter. It's the linkage rods and levers which make or break the installation.
Author:  hantayo13 [ Wed May 25, 2011 6:52 pm ]
only different is 3-4 lever flipped on trans....have a comp plus hurst in mine... would love to find an old mr gasket 4 speed shifter
Author:  DusterIdiot [ Wed May 25, 2011 7:35 pm ]
Post subject:  +1
Josh is right on.
Author:  Exner Geek [ Thu May 26, 2011 6:57 am ]
I am using the Inland shifter which is the only one I have ever seen on an OD trans. Which years and models had a Hurst? Rick, did the rods on Ryan's set up come with the Hurst kit or did you have to use the 3-4 rod that came with the transmission?
Author:  hantayo13 [ Thu May 26, 2011 1:57 pm ]
the inline is made by hurst
Author:  SlantSixDan [ Thu May 26, 2011 2:08 pm ]
'64-'65 A-body w/4-speed had Hurst shifters from factory.
Author:  1974duster kev [ Thu May 26, 2011 3:20 pm ]
I have a hurst shifter but even after rebuilding the 833od somethings up with the shift linkage it's crunchy and clicky to pull into gear not smooth and feels like i'm doing a lightning bolt pattern to go from 2nd to 3rd.
Kev
Author:  AHamilton [ Thu May 26, 2011 3:22 pm ]
Brewers performance has everything needed for a 833OD conversion and parts needed including rearends. www.brewersperformance.com
Author:  Rick Covalt [ Thu May 26, 2011 5:28 pm ]
Post subject:  ?
Seymour,
It has been a long time since I put the 4-speed in the Dart but I am pretty sure I used the factory shifter and rods that came from a 64 Dart GT originally. I am pretty sure I did not purchase anything different for the OD. I had that same shifter and rods in my 65 Valiant first with a non OD 4 speed.
Rick
Author:  DusterIdiot [ Thu May 26, 2011 6:07 pm ]
Post subject:  Yep...
All the 1975-1980 A/F bodies(and trucks to 1987) with A833OD sometimes have the shifter stamped Hurst in small letters, some of the 1978 F-bodies came with the shift stick with the hurst logo stamped in the side on certain vehicles. Inland floor shifters were still used on the A-230 3-spd trannies at that time also.
-D.idiot
