It is currently Mon Jun 08, 2026 7:55 pm
 Post subject: Wheels
PostPosted: Wed Jun 22, 2011 7:41 pm
Hey guys
I've got some 5 spoke wheels from a 99 jeep Cherokee. They are 15x8 with a 5 on 4.5" bolt pattern. I am currently running 235/75r15 tires. Will these tires work on the new wheels. The wheels were free. I will need tires in the next couple months maybe. Should I just wait to put them on when I get new tires and get wider tires? Or can I run my current tires on them. I got a quote for $68 mounted and balanced on the new wheels.
Thanks
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Wed Jun 22, 2011 9:07 pm
Have you test fitted the wheels? Also, Walmart is cheap for mounting and balancing.
PostPosted: Wed Jun 22, 2011 9:20 pm
How do the offset/backspace compare?
PostPosted: Wed Jun 22, 2011 10:49 pm
Josh: no I haven't tested them
Slantvaliant: I have no idea. How do I measure that?
PostPosted: Wed Jun 22, 2011 11:10 pm
The center hole on many Jeep wheels is supposed to be too small or too shallow. One or the other. Check it out before you spend any money.
PostPosted: Wed Jun 22, 2011 11:17 pm
235 75-15 will fit a 8 inch wide wheel fine. I am running them on the 15x8 wheels on my 83 Dodge van. You do need to double check the wheel bolt pattern, the center hub register hole, and the backspacing.
HERE is how to measure offset, backspacing, lug bolt pattern, and the center register/bore.
