| 904 kickdown & throttle adjustment? https://slantsix.org/forum/viewtopic.php?t=45122 |
| Author: | racinkain [ Thu May 26, 2011 8:23 pm ] |
| Post subject: | 904 kickdown & throttle adjustment? |
My car shifts too quick and won't kick into passing gear. It's a 68 Valiant , Slant Six. Just got the car and got it running, now need some direction or drawings of kickdown linkage to make adjustments. Can anyone help me out? |
| Author: | bigslant6fan [ Wed Jun 01, 2011 12:09 pm ] |
| Post subject: | . |
With the engine off,hold the carb wide open,and adjust the linkage so the trans lever is pushed completely to the rear. The kickdown(second gear band) is adjusted by backing off the jamnut, tighten the center bolt to 72 INCH-POUNDS (NOT FOOT-POUNDS!) and back off 2 turns.Retighten jamnut,while preventing the center bolt from moving. |
| Author: | SlantSixDan [ Wed Jun 01, 2011 5:22 pm ] |
As quickly as you can, get the three books described in this thread. |
