It is currently Tue Nov 24, 2026 12:37 am
 Post subject: Flywheel Interchange
PostPosted: Thu May 05, 2011 10:27 pm
I have a 63 Valiant with the original 170 and a four speed. What year did the crank register change? If I get a later 225, what flywheel do I need to make it work? TIA
PostPosted: Fri May 06, 2011 3:03 am
Register size changed at the beginning of the '68 model year. You'll need a '68 and up flywheel. :D
PostPosted: Fri Jun 03, 2011 7:16 pm
Or just have the hole in your current flywheel machined out, (enlarged).
