| which axle is better? https://slantsix.org/forum/viewtopic.php?t=4520 |
| Author: | Duster Driver [ Sat Nov 23, 2002 12:13 pm ] |
| Post subject: | which axle is better? |
I took out my passenger side rear axle. I turned the axle in my hand and the bearings felt perfectly smooth. The one I was going to put in also felt perfectly smooth, but it was stiffer than the one I took out. What I mean is that when I spun it around, it wouldn't go as far before stopping. Which axle should I put back in, the stiffer one or the looser one? Also, do I need to use axle grease? |
| Author: | Doctor Dodge [ Sun Nov 24, 2002 11:26 am ] |
| Post subject: | 7 1/4 Axle Bearings |
With these bearings, "stiffer" is better. I base this on the fact that new ones are pretty tight & stiff when you get them. These are sealed bearings and come "pre-lubed" so no extra grease is needed on the bearing but put a little grease on the seal surface. DD |
