| 1968 Dart thinking of rasing my front suspension up https://slantsix.org/forum/viewtopic.php?t=45208 |
| Author: | USAJon [ Sun Jun 05, 2011 3:04 pm ] |
| Post subject: | 1968 Dart thinking of rasing my front suspension up |
I ahve never done this..how hard...any videos..any advice |
| Author: | zorg [ Sun Jun 05, 2011 3:40 pm ] |
Step 1: Using a 3/4' wrench, tighten the torsion bar adjusting bolt until you have achieved the desired ride height. (It sticks straight down at the inner end of each LCA.) Step 2: Go get an alignment. |
| Author: | USAJon [ Sun Jun 05, 2011 4:41 pm ] |
OK which way makes it rase the ft end |
| Author: | THOR [ Mon Jun 06, 2011 8:32 am ] |
Be wary of your upper control arm bushings when raising and lowing ride height. You will need: A ratchet and 3/4" socket, Tape measure, Flat ground Turn the torsion bar adjusting bolt clockwise to increase height, and counter-clockwise to decrease height. Use the tape measure to ensure both sides are even. As Zorg said, go get an alignment afterward. If you move the front up or down enough, it will change how the car rides/handles/stops. ~RDE~ |
