dyno results
https://slantsix.org/forum/viewtopic.php?t=4526
Author:  andrew [ Sun Nov 24, 2002 6:32 am ]
Post subject:  dyno results
The engine is stock bottom end, ..060 over bore,1.74 intake valves,1.44 exhaust, light porting and a comp cam. Its turbo is a t3 and it is intercooled.
208 hp and 313 tq at the wheels. 8 psi
The pics are in the drag strip sect
Andrew Wagner
:twisted:
Author:  slantzilla [ Sun Nov 24, 2002 11:36 am ]
Those are some pretty good numbers Andrew! :D Did you ever get it back out to the dragstrip yet? :shock:
Author:  Bob D [ Sun Nov 24, 2002 4:24 pm ]
Hey Andrew that's great. At what RPM were these numbers taken? Anyone have any idea what that would translate to in terms of engine HP? I believe Andrew has a standard transmission.
Author:  slantzilla [ Sun Nov 24, 2002 5:09 pm ]
I believe standard loss is figured at around 18%. That would put Andrew right around 250 or so at the crank. :D :shock:
Author:  andrew [ Sun Nov 24, 2002 10:17 pm ]
Post subject:  dyno
the peak tq was at 3000 rpm and the peak hp was at 4000 rpm. I can't get to the drag strip until the end of winter.
Andrew wagner
:P
Author:  72Duster [ Wed Nov 27, 2002 11:06 am ]
Great results andrew ! What kind of head gasket do you use ?
Christian
