It is currently Thu Oct 08, 2026 10:09 pm
PostPosted: Tue May 24, 2011 3:00 pm
Runs fine when opened up more though.... I've been searching the site for answers but I use my phone for web browsing and its not ideal... I replaced the bowl gasket because it was leaking the carb has never given my problems before so I didn't do a full rebuild that was two or three days ago cars been running great...
untill today when I was pulling onto a busy road the car died and then it ran really rough.
Car starts right up and idles real slow and rough out of the blue... I used the walker kit and my float was fine... I can drive it but I have to kinda punch it off a stop or it dies its a holley 1920 has a holley rebuilt sticker on it...
Its doing the same thing again only less extreme it still dies with light throttle... if i open it up its fine but if i crack it a littlest it starts to stumble and dies, its also fairly hot out here in SC and it seems to happen when hot...
PostPosted: Tue May 24, 2011 3:25 pm
I was thinking vac leak but it seems a-ok
PostPosted: Wed May 25, 2011 12:07 pm
This morning I went out there to work on it started right up and idled smooth and sounded great... then I tapped the gas to bring the idle down and it died on me again...
PostPosted: Wed May 25, 2011 1:22 pm
Have you connected a vacuum gauge to it yet? If so, what are you reading?
PostPosted: Wed May 25, 2011 4:28 pm
No, I have lost almost all my tools over the course of moving arund the country this is the first car I have drivin in almost 3 years!
PostPosted: Wed May 25, 2011 5:49 pm
Well I screwed in the idle screw and then backed it out untill I found a sweet spot... its still kinda sputtery though... more than it was a couple days ago....
PostPosted: Thu May 26, 2011 8:41 am
Pick up a cheap one at harbor freight. Without a vac gauge, tach and timing light everything is just a guess.
PostPosted: Sun Jun 05, 2011 11:36 am
Got the idle handled, however I'm gettin a intermittent puff sound accompanied by suction from my tailpipe... I also have a exhaust leak on my exhaust manifold... however its been like that since I bought it. Thanks for all the help and info from you all!
Ps planning to go to harbor freight this week, I need feeler gauges as well.. anything else I need to pick up besides vac gauge timing light?
PostPosted: Sun Jun 05, 2011 12:40 pm
Suction in the tailpipe could indicate an exhaust valve problem, sticking perhaps.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jun 05, 2011 8:45 pm
Recommend considering a cylinder compression test gauge, in addidtion to the other stuff.
In my experience, a chuff or pfft from the exhaust pipe is a burned valve. The only thing I've run across that was similar was a sticking hydraulic lifter.
You can't fix stupid. - Ron White
PostPosted: Sun Jun 05, 2011 8:54 pm
Site Admin
What is your valve lash set to?
CJ
PostPosted: Sun Jun 05, 2011 9:12 pm
Only had the car a lil while havnt adjusted the valves yet
PostPosted: Sun Jun 05, 2011 9:13 pm
Site Admin
Do that first. Sounds like a tight exhaust valve.
CJ
PostPosted: Tue Jun 14, 2011 12:26 pm
fixed it! all smoothed out!
PostPosted: Tue Jun 21, 2011 12:57 pm
set my valves to .10 and .20 took my time and it was running like a champ all week to stumble no bog perfect! started it up this morning and went inside came back out and car had died...
im getting the chuff from the tailpipe (though not as bad as before) and a lope and a lot of vibration...
it dies under light throttle and the less i open it the faster it dies...
Users browsing this forum: Bing [Bot], Google [Bot] and 34 guests
