| deep factory 904 transmission pan ? https://slantsix.org/forum/viewtopic.php?t=45274 |
| Author: | USAJon [ Fri Jun 10, 2011 3:02 pm ] |
| Post subject: | deep factory 904 transmission pan ? |
is there any factory deep transmission pan made...interchange..looking for more capacity without the summit $200 price. thanks |
| Author: | SlantSixDan [ Fri Jun 10, 2011 3:10 pm ] |
The current-production pan is deeper than the ones that came standard when slant-6 vehicles were being built. Assuming you're building a 904, pan is p/n 52118 779AB, and they even include a spiffy magnet to catch metallic shavings. Also get the really nice double-seal, reusable rigid pan gasket P/N 4295 875AC. |
| Author: | USAJon [ Fri Jun 10, 2011 3:18 pm ] |
any idea how much more capacity dan da man... |
| Author: | Pierre [ Fri Jun 10, 2011 3:26 pm ] |
There are aftermarket pans that are +2 quarts. Check here for both the MP stamped unit and cast ones. Good plus is the drain plug too. I second the nice gasket Dan mentioned. |
| Author: | USAJon [ Fri Jun 10, 2011 9:11 pm ] |
looks like the stamp steel one is 1 quart the cast aluminium is 2 quarts or larger..I found a TCI cast aluminum 2 quart unit for $83 delivered..anyone ever had issues with TCI ? also on some jeep 4x4 forums they talk about installing a temp sending unit in the corner of the pan...is that just for 4x4 app. or do Drag racers do that too? |
| Author: | Dart270 [ Sat Jun 11, 2011 7:32 am ] |
That is a steal for the TCI pan. Stock stamped ones I've seen give the same extra cap as TCI - 2 qts. Lou |
| Author: | slantzilla [ Sat Jun 11, 2011 10:12 am ] |
One of the deep pans I have is a stock pan off an A-500 or some derivative thereof. IIRC, it's a truck pan. |
| Author: | USAJon [ Sun Jun 12, 2011 1:02 pm ] |
Quote: That is a steal for the TCI pan. Stock stamped ones I've seen give the same extra cap as TCI - 2 qts.
looks like they pulled the eBay listing..Lou http://cgi.ebay.com/ebaymotors/ws/eBayI ... AUS%3A1120 I have sent an email telling i wanted to buy, but they have not answered yet.. |
| Author: | Joshie225 [ Sun Jun 12, 2011 3:13 pm ] |
I'm curious. What problem are you seeking to correct with the increased fluid capacity? |
| Author: | USAJon [ Sun Jun 12, 2011 3:28 pm ] |
no problems but I have always like extra capacity in the transmission for racing. heat will kill an auto trans prematurely. on hauling packages on trucks they have a trans cooler and I do have a tow hitch..ha! |
| Author: | Joshie225 [ Sun Jun 12, 2011 4:28 pm ] |
I know about transmission coolers, but that's not what we're talking about. Two quarts more fluid will only slow the increase in fluid temperature slightly which is one reason why I was asking. Deep pans are really of best use when the fluid pickup becomes troublesome on high G launches. |
| Author: | USAJon [ Sun Jun 12, 2011 5:09 pm ] |
Quote: I know about transmission coolers, but that's not what we're talking about. Two quarts more fluid will only slow the increase in fluid temperature slightly which is one reason why I was asking. Deep pans are really of best use when the fluid pickup becomes troublesome on high G launches.
well I do drag race more then drive on the street. I guess most deep pans were for OD trans/work vehicles/4x4'sI always ran a deeper pan for the strip..probably old sckool peeps influence me. here's some nice pans for various apps. http://www.partshp.com/Pans.htm |
| Author: | 63dartdude [ Sun Jun 12, 2011 7:29 pm ] |
http://www.pacefabrication.net/services.html should be an excellent source. |
| Author: | StrokerScamp [ Wed Jun 15, 2011 4:41 am ] |
The reason you see jeepers talking about the trans temp gauge install is kinda two fold. First, is the obvious. Slow crawling in 4WD can increase trans temps a bunch. Then there's the problem with the 42RLE in the new Wranglers that Chrysler does NOT want to address. A lot of these new Jeeps have burned. The cause has been narrowed down to trans fluid overheating, boiling out of the dipstick tube onto the exhaust manifold and causing a fire. The resulting fire takes out nearby fuel lines and the rest is history. I had an 08 Wrangler and one of the first things I did was install a hardlined cooler in line with the factory one. If you run an extra capacity pan, I would not think a fluid temp gauge would be necessary, but it couldn't hurt I suppose. |
| Author: | bigslant6fan [ Wed Jun 15, 2011 11:39 am ] |
| Post subject: | . |
While you got the pan off,check the line pressure adjustment. See my post on page 2 "shift kit,worth it?" |
