It is currently Sat Jun 13, 2026 9:45 am
 Post subject: Cam Timing Offset Keys?
PostPosted: Wed Jun 08, 2011 6:49 am
Hi all,
My local auto parts people looked at me like I had three heads when I said I needed offset keys to degree the cam in the Dart.
Is there another name for them?
Where do you get them from?
Thanks - Mac
PostPosted: Wed Jun 08, 2011 9:20 am
We don't use keys. We use bushings in the cam sprocket same as a Chevy of big block Chrysler.
PostPosted: Wed Jun 08, 2011 4:09 pm
You can see some examples here. They can be had from many sources, all suppliers of cams should have them.
Olaf.
Aspenized
PostPosted: Thu Jun 09, 2011 7:46 pm
Car Model: 64 Valiant
You have to drill the cam gear to install them also, so read the directions carefully to make sure you get the right one(drill bit).
