| 1/4 mile drag racing 4 barrel intake which is best? https://slantsix.org/forum/viewtopic.php?t=45297 |
| Author: | USAJon [ Mon Jun 13, 2011 8:55 am ] |
| Post subject: | 1/4 mile drag racing 4 barrel intake which is best? |
who makes the best 1/4 mile drag racing intake for a 4 barrel carb? thinking of going that route.. |
| Author: | Joshie225 [ Mon Jun 13, 2011 9:21 am ] |
The Offy is better at low RPM and works easier with a stock exhaust manifold. Unless you go big with the cam, compression and head work it's likely to give you better ETs than a Clifford. A 500 CFM Holley 2bbl with an adapter matched to a Super Six 2bbl intake works quite well also and is potentially much cheaper. |
| Author: | 66aCUDA [ Tue Jun 14, 2011 7:15 am ] |
Depends on who you talk to and haw you build your setup. ANY of the 4 bbl setups will work well. Frank |
| Author: | Dart270 [ Tue Jun 14, 2011 10:52 am ] |
Yep, VERY dependent on motor buildup and desired driving characteristics. Lou |
| Author: | NCDemon1971 [ Wed Jun 15, 2011 4:32 pm ] |
Pretty much any post above is correct. I have seen stock manifolds that were modded to accept four barrel carbs that worked extremely well. On the drag strip, I don't think any of them are worth that much over another one. This is my OPINION. I do know that the Offenhauser is a great piece for the street. Lots of people like the Clifford for higher horsepower builds. I am going to use a Weiand on my next motor because it's what I have. I've seen them run good on other motor's, so why not mine? I wouldn't fret to much over the intake because the head is the place to spend the coin by far. Good luck! |
