| how much lube 833od https://slantsix.org/forum/viewtopic.php?t=45316 |
| Author: | Turbo Toad [ Tue Jun 14, 2011 5:58 pm ] |
| Post subject: | how much lube 833od |
Maybe somebody can answer a couple questions for me about how much lube will a 833od case hold and my second question can I change the fluid out while the trans is in the car or do I have to take it out and place it on its side and fill it from the plug Thanks Aaron [/code] |
| Author: | Joshie225 [ Tue Jun 14, 2011 6:52 pm ] |
About 8.5 pints. There is a fill plug and a drain plug. Add oil until it's even with the bottom of the fill plug with the vehicle level. |
| Author: | Turbo Toad [ Tue Jun 14, 2011 7:10 pm ] |
Joshua Thanks FYI my turbo motor and transmission are installed in the TOAD I have some minor things to do but I'm looking at possible firing the TURBO TOAD up this week Aaron |
| Author: | hantayo13 [ Wed Jun 15, 2011 2:43 am ] |
I use a funnel in a piece of 3/8 hose.run hose up along engine and secure it pour oil in and watch fill hole when it starts to run out hole ,remove hose ,place end in oilcan and replace plug keep on roddin' |
| Author: | 70valiant [ Wed Jun 15, 2011 3:47 am ] |
Just out of curiosity, what are you using for "lube"? |
| Author: | Turbo Toad [ Wed Jun 15, 2011 5:55 pm ] |
Quote: Just out of curiosity, what are you using for "lube"?
I'm going to run the passion performance product.Aaron |
| Author: | 70valiant [ Thu Jun 16, 2011 3:10 am ] |
The owners manual for my Volare calls for ATF in the 833-OD |
| Author: | Joshie225 [ Thu Jun 16, 2011 8:03 am ] |
You can put a lot of different lubricants in an A833 and have it work acceptably. The last one I had really liked Red Line MT-90. I'll most likely use it again in the Barracuda when the time comes. |
| Author: | 70valiant [ Thu Jun 16, 2011 10:25 am ] |
The manual states atf is used from the factory but if it makes to much noise you can remove the atf and put in 90 . |
| Author: | 1974duster kev [ Thu Jun 16, 2011 12:37 pm ] |
I got 90 in mine and i use the screw on lid with the plunger thing on it then just pump away until the jug is empty or my trans starts dripping from the fill plug. Kev |
