| choice of head https://slantsix.org/forum/viewtopic.php?t=45332 |
| Author: | Rost310 [ Thu Jun 16, 2011 1:34 pm ] |
| Post subject: | choice of head |
I have a 73' engine block and two heads 73 and 80 years. Both in good condition. What is preferable? |
| Author: | Dart270 [ Fri Jun 17, 2011 1:30 pm ] |
You will get differing opinions depending on who answers. Performance-wise, they will have identical potential. 73 has drool tubes so some don't like those for small oil leaks. 80 is a heavier head (few lbs). Lou |
| Author: | emsvitil [ Fri Jun 17, 2011 11:53 pm ] |
You can use the extended tip spark plugs with the drool tube heads. The extended tip plugged engines tend to run smoother. |
