It is currently Fri Oct 09, 2026 5:02 pm
 Post subject: Engine Identification
PostPosted: Sun Jun 19, 2011 6:06 am
Need a little help ID'n an engine I got last night. SL6 out of a truck, mid 60's early 70's. Ford blue, casting numbers are 2463430-3. Thanks
1982 W150 225 SL6 4X4 4 SPD
PostPosted: Sun Jun 19, 2011 8:44 am
1960-1967 225 block.
See HERE
PostPosted: Sun Jun 19, 2011 2:01 pm
what are the benefits/drawbacks to spark lug tubes?
PostPosted: Sun Jun 19, 2011 2:24 pm
Well, the benefits are that the factory used them in the 60-about 77 or 78 cylinder heads. If you don't use spark plug tube on a head designed for them, then (a) you have to leave the little gaskets on the plugs when you install them, (b) you might drop the plugs into the lifter gallery during installation, and (c) oil will leak out all over the side of the block when the motor is running.
PostPosted: Sun Jun 19, 2011 3:16 pm
Wider selection of spark plugs available for the tube-type heads.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 26 guests
