| honing a block after storage https://slantsix.org/forum/viewtopic.php?t=4537 |
| Author: | Dart270 [ Tue Nov 26, 2002 6:58 am ] |
| Post subject: | honing a block after storage |
Hey folks, Now that I have a garage, I am getting around to building a short block I picked up 7 years ago in LA. The guy I got it from (pretty reliable friend) said the block was all honed for the pistons/rods he gave me with it. The pistons/rods (assembled) are not marked for which bore they go into. Is it fairly common for modern pistons and machining practices to bore/hone all cylinders to the same size and have all the pistons be exactly the same? I can take all 6 pistons and put them in one hole and 0.002-0.0025" feeler gauges will just fit between the piston skirt and the bore (same clearance on all to < 0.0005"). Should I get telescoping gauges and check all bores/pistons for individual fit? These are STD Sterling pistons for a Chevy 2.8L V6 (3.504" bore) mounted on 198 rods - all balanced. This guy had some good connections to race machine shops in LA, so he may have had it machined on fancy equipment capable of these tolerances. Unfortunately, I completely lost track of this guy after he moved out of LA. Also, the bore finish is cross-hatched and has a finer finish than I remember my previous new engines having, but has a fine surface rust on it due to long storage. Should I run a drill hone in there (or, Thanks very much, Lou |
