It is currently Fri Oct 09, 2026 1:16 am
PostPosted: Wed Jun 22, 2011 5:01 pm
so im driving my car finally, still single barrel, still stock,
so im driving, at times i have to nearly floor it to pick up a MPH or 2... then out of the blue... BOOM it catches up and starts to accelerate faster... so then i have to release to compensate... now its not like a dragster accelerate but its like a "okay okay yay 44... 45.46.4748 woah woah woah!"
now my theory is timing... still... i just want to make sure im on the right path...
74 plymouth duster, 225 single barrel slant six
PostPosted: Wed Jun 22, 2011 5:07 pm
Are you sure its not just your kickdown engaging? When you're accelerating at 40mph or so and slam the gas, the car wont pick up a whole lot of speed until the kickdown engages and downshifts. Then it'll go into 2nd and pick up speed until it shifts back up to 3rd. It's like a passing gear.
PostPosted: Wed Jun 22, 2011 5:27 pm
Pull the shifter down to second and floor it to test, that theory sounds plausable provided the car runs normal at slower speeds like in 1st gear and what not.
Kev
PostPosted: Thu Jun 23, 2011 8:49 am
Is the accelerator pump in the cab working correctly?
How about the vacuum advance on the distributor, is that holding vacuum and connected to a "reliable" ported vacuum source? (is it connected directly to the carb?)
PostPosted: Thu Jun 23, 2011 9:54 am
With the engine off and the air cleaner removed, have someone press the accelerator smoothly but quickly to the floor, starting at about 1/4 pedal.
Does the carb throw a good stream of gas into the manifold?
That's the test for the accelerator pump...
PostPosted: Sun Jun 26, 2011 4:33 pm
make sure the bolt for the dizzy is tight... i had mine loosen up and do all kinds of weird things untill i caught it
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Jun 26, 2011 4:54 pm
sock in gas tank...
slant six's RULE!
http://www.usajon.com
Users browsing this forum: DuckDuckGo [Bot] and 18 guests
