| valve ajustment blues https://slantsix.org/forum/viewtopic.php?t=45447 |
| Author: | fatdaddyadam12 [ Mon Jun 27, 2011 5:11 pm ] |
| Post subject: | valve ajustment blues |
Hi ya all. Ok I set the valves on my 78 super six and now it acts like its flooded when I start it. Runs great on the road, idles good. I have set valves on many different engines so I'm no stranger to this. Help please! Thanks Adam |
| Author: | SlantSixDan [ Mon Jun 27, 2011 5:25 pm ] |
Can you describe for us the procedure you used to set the valves on this engine? |
| Author: | fatdaddyadam12 [ Mon Jun 27, 2011 7:07 pm ] |
Oops I posted my reply in the wrong spot. Ok I brought each cylinder to TDC on the compression stroke and set intakes on 10 and exhausts on 20. Engine was over night cold. |
| Author: | ceej [ Mon Jun 27, 2011 7:12 pm ] |
It's likely too tight then. With the OEM cam, if your going to set it cold, add a thousandth or two. The FSM method is set running, hot. CJ |
| Author: | SlantSixDan [ Mon Jun 27, 2011 7:33 pm ] |
See valve adjustment procedure. |
