| 727 shift points https://slantsix.org/forum/viewtopic.php?t=45451 |
| Author: | mrfoochie [ Mon Jun 27, 2011 8:16 pm ] |
| Post subject: | 727 shift points |
howdy folks, i have a 727 sitting behind my trusty slant in my 66 a100 and the shift from 1st to 2nd seems a bit hard... it really winds out in first before shifting... drops into 3rd nicely though... is this just a kick down linkage adjustment or do i need to drop the pan and give her a tweak? |
| Author: | icepaddles [ Tue Jul 19, 2011 4:05 pm ] |
I would go after a sticky 1,2 shift valve, the goveror pressure overrides the kickdown at a certain speed (other end of valve). If th 2,3 shift will do all you ask and first and second gear are good physicaly, a delay might be that it sticks untill the govenor pressure is high enough. I would take the valve body down and inspect the 1,2 shift curcuit, (two valves and a ball or something). The obstuction could fall away with fluid when you remove the valve body so if you don't find something its o.k., you might look for a little speck of dark like sand or gasket or you might look for a little glob of cloth saturated with tranny fluid. Pull some fuzz of a shoelace and mix it with tranny fluid if you want an idea. Even transmission shops won't clean a valve body on a rebuild unless that was diagnoised so trust me you don't want to add to you problems. |
| Author: | icepaddles [ Wed Jul 20, 2011 3:22 pm ] |
Should be cut and dry operation with a service manual to find the shift valve, and pay attention to the torque of the valve body bolts, you can warp the valve body with pressure from a screw driver and you hand. |
| Author: | mrfoochie [ Fri Jul 22, 2011 9:41 pm ] |
thanks fellas... i have a service manual i'll take a peek... |
| Author: | Fopar [ Fri Jul 22, 2011 10:25 pm ] |
Check to see the kickdown linkage is set correctly first. Might be it is set to long. Richard |
