It is currently Sat Nov 14, 2026 4:11 pm
PostPosted: Fri Nov 06, 2020 12:35 pm
Car Model: 1964 Dodge Dart GT
Planning to install a Holley Street Avenger 2300-series two-barrel (PN HLY-0-80350) and use the aussiespeed 2 BARREL SHORT RUNNER MANIFOLD on my 1964 Dodge Dart. As you guys know it has the rod linkage. How do I change the linkage to cable and what parts do I use?
I was thinking I could swap this gas pedal but not sure if it could work.
https://www.ebay.com/itm/Street-Hot-Rod ... 4902.l9144
PostPosted: Fri Nov 06, 2020 3:58 pm
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
The easiest and cleanest fix is to find a 64-66 gas pedal and cable from a V-8 car. It bolts right up to the holes from the slant pedal. If you can't find one of those, a pedal and cable from a 67 and up will work but you have to drill the firewall for the different mounting bolts. It's not hard, but the later pedal hinges from the top while the early one hinges from the bottom.
Users browsing this forum: Amazon [Bot] and 11 guests
