engine identification
https://slantsix.org/forum/viewtopic.php?t=4554
Page 1 of 1
Author:  amjbrett [ Fri Nov 29, 2002 11:07 am ]
Post subject:  engine identification
how do i tell if an assembled engine is a 198 ?
Author:  slantzilla [ Fri Nov 29, 2002 2:35 pm ]
Look between the alternator bracket and the head. There is a stamping pad on the block that sticks out from under the head. If you scrape all the gunk off, the CI number will be stamped there.:)
Author:  Doctor Dodge [ Fri Nov 29, 2002 10:14 pm ]
Post subject:  Engine ID Numbers
Here is a look at the boss on the block and the ID numbers stamped into it.
This engine is a 1962 aluminum block 225 (TA22)
A 198 will have some letters and "19" or "198" stamped there.
