| cooling problem https://slantsix.org/forum/viewtopic.php?t=4557 |
| Author: | fin [ Sat Nov 30, 2002 1:04 am ] |
| Post subject: | cooling problem |
Hi First, I'm sorry, my english is not very good. My super six has cooling problems. In summertime when the air temperature is high, the engine is running after 20 mile run very hot. It's not boiling if I keep speed under 55 mph. And now wintertime the engine wont get the temperature. It's running cold all the time. I have changed thermostat, but it didn't help. |
| Author: | Chuck [ Sat Nov 30, 2002 11:19 am ] |
Do a search on "overheating". Julie Roth had a lot of problems with overheating and there are lots of suggestions in that thread. |
| Author: | fin [ Sat Nov 30, 2002 8:36 pm ] |
I already read everything, but why the engine is not getting the normal temperature at cold weather. |
| Author: | bud L. [ Sat Nov 30, 2002 9:28 pm ] |
| Post subject: | too hot/ too cold |
If there is sufficient coolant, and the thermostat is the correct value and functioning properly, then I see no reason for it to run too cold. The thermostat's job is to withold circulation until the specified operating temp is reached. |
| Author: | Doctor Dodge [ Sat Nov 30, 2002 9:32 pm ] |
| Post subject: | Too Cold |
Is the heater core by-passed? That will keep the engine from warming-up. If it is not that, then the thermostat is stuck open. Look inside the radiator when you first start the car, cold. If the coolent is moving in the radiator tank, the thremostat is stuck open. DD |
| Author: | Dart270 [ Sun Dec 01, 2002 7:20 am ] |
| Post subject: | reversed thermostat? |
If the thermostat is reversed, it may stick too. It should have a marking on it that says "rad" or "head". Lou |
| Author: | fin [ Mon Dec 02, 2002 9:23 am ] |
Heater core is not by-passed.Thermostat is not reversed and it's closed when I start motor, so it's not stuck open. Maybe I'll have to clean the whole cooling system. |
| Author: | Fin [ Mon Dec 02, 2002 10:01 am ] |
What is the correct radiator gap pressure. I have 50 kpa (7 PSI) |
| Author: | Dart270 [ Mon Dec 02, 2002 12:48 pm ] |
| Post subject: | should be higher |
The factory cars, I believe, had a 13-15 psi cap. I run these higher pressure caps and have never had a cooling problem. Lou |
