| Speedometer cable thread https://slantsix.org/forum/viewtopic.php?t=45619 |
| Author: | coconuteater64 [ Fri Jul 15, 2011 6:07 pm ] |
| Post subject: | Speedometer cable thread |
This has probably been discussed but I couldn't find it if it was. Anybody know what the thread is on an A833OD speedometer cable/trans? My truck does not have a speedo, and I want to make sure when I upgrade to a programmable speedo I get a sender that will screw on properly to the trans. |
| Author: | Joshie225 [ Fri Jul 15, 2011 7:19 pm ] |
You can get an electronic sender that fits directly. My '96 Dakota had one. I know other Dodge trucks use them too. I'd get one from a Pick-N-Pull so you get the gear along with the sender. |
| Author: | coconuteater64 [ Fri Jul 15, 2011 7:30 pm ] |
Thanks! I'm gonna give the P-N-P a shot next off day. |
| Author: | DusterIdiot [ Fri Jul 15, 2011 10:14 pm ] |
| Post subject: | Yep... |
Quote: You can get an electronic sender that fits directly.
If you find your pick apart pulls the trannies and trashes the sender or won't allow you to pull that part...you can order An Autometer 5291 or a Summit G-2887-1 for the 50-60 buck range.Because I'm running a combination on the Hpak Duster that Mopar never intended (4.56 rear gears and 205/70R14 tires), it became necessary to use the Autometer 5291-threading is something like 7/8-18... I ran it to a Autometer digital programmable speedo (use whatever speedo gear is handy in your tranny...just have to drive a couple miles, set the program button and you're golden)... -D.Idiot |
| Author: | coconuteater64 [ Sat Jul 16, 2011 11:09 pm ] |
Thanks! That was exactly the info I needed. |
