| Rear oil pump cover question https://slantsix.org/forum/viewtopic.php?t=45705 |
| Author: | lancer61 [ Sun Jul 24, 2011 12:21 pm ] |
| Post subject: | Rear oil pump cover question |
Has any one here messed with a 904 with both front and rear oil pumps ? The rear oil pump cover needs to be aligned with a special tool (C-3762), it look's like it is a bit picky to get this right, when you put back to extension housing the outputs shaft makes a lot of resistance when rotating it, I removed the housing and loosend the oil pump cover and tried to align it a little better and this time the output shaft rotates a little easier but it is still not as it was before, so the question is, any ideas on how to get this right ? |
| Author: | lancer61 [ Tue Jul 26, 2011 3:21 pm ] |
If any one is interested I will answer my own question. Use a piece of cardboard, 0.013" thick, wrap it around the guvernor support without the rings installed and use that to center the oil pump cover. |
