| Somender Singh Grooves https://slantsix.org/forum/viewtopic.php?t=45733 |
Page 1 of 2 |
| Author: | icepaddles [ Tue Jul 26, 2011 3:00 pm ] |
| Post subject: | Somender Singh Grooves |
Has any one triied this? I am going to. http://somender-singh.com/content/view/7/31/ |
| Author: | slantzilla [ Tue Jul 26, 2011 3:19 pm ] |
Cool! You can be the next one to discover that they don't do anything. |
| Author: | Joshie225 [ Tue Jul 26, 2011 3:19 pm ] |
Care to discuss crevice volume? How about flame quench? Here is my 170's cylinder head.
| Author: | Joshie225 [ Tue Jul 26, 2011 3:20 pm ] |
Quote: Cool! You can be the next one to discover that they don't do anything.
Aw Dennis, at least tell him why or make him think a little.
| Author: | CNC-Dude [ Tue Jul 26, 2011 3:20 pm ] |
It will only help(in theory)if you have a tight quench in the engine. I know several Winston Cup engine builders who have done some R&D with that concept and never went any farther with because it was of no benefit to them. A lot of people feel its just snake oil and nothing more. |
| Author: | SlantSixDan [ Tue Jul 26, 2011 4:36 pm ] |
| Post subject: | Re: Somender Singh Grooves |
Quote: Has any one triied this?
*groan* See here, here, here, and here. Quote: I am going to
Not if you're smart, you aren't.
| Author: | olafla [ Tue Jul 26, 2011 5:39 pm ] |
Quote: If you are interested to explore what this really means for the whole world, you can see a YouTube video of Martynelli from Spain cutting a nice pretty groove with nothing more than a hacksaw blade, triangular file and some sand paper, in less than four minutes!
If I can do that in only three minutes, so how much extra power do I get by cutting down on the time it takes by 25%?If you do it with a dremel-tool, you may get a double bonus here; just remember to make a cut around the venturi area of the carb as well, like the GadgetmanGroove, then you can decrease emissions, increase power and improve milage even more! If it sounds too good to be true, ... Olaf. |
| Author: | Brussell [ Tue Jul 26, 2011 7:03 pm ] |
"Even though this test didn't take advantage of the Groove's main strengths (a 'worst case scenario' in other words) the dyno still showed a +6 hp power increase and a smoothing of the power band through all rpm's." Lol... fair bit of work for +6hp. Don't do it. |
| Author: | CNC-Dude [ Tue Jul 26, 2011 7:10 pm ] |
What engine was the original testing done with. |
| Author: | icepaddles [ Tue Jul 26, 2011 8:14 pm ] |
I do suppose it would increase the surface area (actual quench area) too, I might do it if I had a .010" head gasket, thanks for reminding me. |
| Author: | Brussell [ Wed Jul 27, 2011 12:08 am ] |
As Dan has mentioned above if you view the links on the site that show tests on the method. They will often achieve increased power MPG etc but also because they put a new carb on the engine, upped the compression, changed the cam, did a complete rebuild etc. If it worked as well as the site suggests the idea would have been taken and turned into a money maker. |
| Author: | slantzilla [ Wed Jul 27, 2011 2:15 pm ] |
One of the engine builders on Moparts dyno'd a 360 after he put the grooves in it. His testing showed that they did absolutely nothing. Same motor, same heads, no new parts except gaskets. |
| Author: | Joshie225 [ Wed Jul 27, 2011 3:05 pm ] |
I'd be willing to bet the grooves increased HC emissions. |
| Author: | SlantSixDan [ Wed Jul 27, 2011 3:21 pm ] |
Quote: I'd be willing to bet the grooves increased HC emissions.
I wouldn't bet against you!
| Author: | icepaddles [ Wed Jul 27, 2011 3:31 pm ] |
http://speedtalk.com/forum/viewtopic.php?t=4069 |
| Page 1 of 2 | All times are UTC-07:00 |
