What is this thingy?
https://slantsix.org/forum/viewtopic.php?t=45761
Author:  kipamore [ Thu Jul 28, 2011 8:24 pm ]
Post subject:  What is this thingy?
So the other day I had the thermostat housing off to put in a new thermostat. Looking into the hole, there's this piece of wire, little thinner than a coathanger, bent at 90 degrees, running along the tops of the exhaust ports. I wiggled it, it's totally loose. What is this, why is it there, what does it do, how did it get there, and should I remove it?
Kip on Truckin'
Author:  Fopar [ Thu Jul 28, 2011 8:30 pm ]
:shock: It's wire used to hold part of the casting when the head was cast. Just pull it out (helps kep the rust down) it doesn't do anything any more.
Richard
Author:  olafla [ Thu Jul 28, 2011 8:32 pm ]
It is leftovers from the casting process, just yank it out and throw it.
Olaf.
Author:  olafla [ Thu Jul 28, 2011 8:34 pm ]
Hah, you beat me by two minutes there, Richard, it clearly shows my fingers are slowing down! :lol: :lol:
Olaf.
Author:  Reed [ Thu Jul 28, 2011 9:45 pm ]
It is a secret fuel booster installed in only factory test vehicles. Most were removed and destroyed by oil company operatives working for all the auto manufacturers, but a few made it out the back door.
And if you believe that, I have a bridge to sell you in Utah.
Author:  slantvaliant [ Fri Jul 29, 2011 6:39 am ]
It's an alien implant, for tracking purposes.
You don't think the aliens were only interested in people, do you?
