| Ignition problem? https://slantsix.org/forum/viewtopic.php?t=45787 |
| Author: | Ross [ Mon Aug 01, 2011 12:04 am ] |
| Post subject: | Ignition problem? |
I've had my hei ignition on for almost 3 months now. Worked great till about a week ago it started having problems when it got to be up in the high 80's. My ignition module has a big heat sink that is mounted to the fender. Well it started out being hard to start, I did have the carb boil the gas out one day cuz of lack of a heat shield. Got the carb issue fixed. It has progressively gotten worse, the hard starting. And when i do get it started it sounds like a poppin Johnny. It also hesitates between 1000-1400 rpms and it sputters a lot. Thought it was the carb. Fixed the vac leak. Still runs bad. It's kind of embarrassing to sit there for a good few minutes cranking. Is it my module or a bad coil? Also when I get it started after it has sat awhile it puffs out a cloud of black smoke upon firing up. Thanks for the help Cody |
| Author: | Joshie225 [ Mon Aug 01, 2011 12:09 am ] |
Probably still the carb. Check for spark when you're having trouble getting it started to be sure. |
| Author: | Ross [ Mon Aug 01, 2011 1:52 am ] |
I've used two different carbs with the same results. But I'll check for spark next time I have trouble starting it. Cody |
