| 727 for my slant six https://slantsix.org/forum/viewtopic.php?t=45796 |
| Author: | 63dartgt [ Mon Aug 01, 2011 6:55 pm ] |
| Post subject: | 727 for my slant six |
i want a performance 727 for my soup'd 225 where should i look i am replacing my old push button |
| Author: | SlantSixDan [ Mon Aug 01, 2011 6:58 pm ] |
This is not a smart idea. You'd have to make a bunch of costly, difficult mods to fit a 727 in your car, and you'd wind up with an unnecessarily heavy, unnecessarily power-hungry transmission. You don't need a 727; a 904 in stock form is plenty robust for even a stout slant-6, and the 904 can be built up to take whatever most any slant-6 (or even a pretty strong V8) can dish out. |
| Author: | 63dartgt [ Mon Aug 01, 2011 7:11 pm ] |
I am bored out over .060 my head is milled .125 is port match for my intake enlarge bowls & valves 1.6 rockers high lift springs true dual exuast 4 barrel 525 road demon junior And a cam .619 lift running dur of 274 advanced dur 320 power range between 4500 7k rpm 2300 stall tired of breaking 904s i have twisted the input shaft off two and other problems in my lil dart your fast on the response |
| Author: | WagonsRcool [ Mon Aug 01, 2011 9:59 pm ] |
If you are (were) running '67 & earlier "small" converter then I'm not surprised that you broke the input shafts. Later 904s lived behind 340s & 360s, so if you get the right parts (HD/ racing) then you''l be fine. (hell, some guys run 904s behind BB... & have them live! The only question is what year crank is in your engine? I don't know if there is any way to fit a later (68-up) "large" converter & input shaft into a 67-down crank. |
| Author: | SlantSixDan [ Tue Aug 02, 2011 8:13 am ] |
Sure there is: enlarge the crank counterbore! If we're going to later whole transmission, though, we're losing pushbutton shift. |
| Author: | 63dartgt [ Tue Aug 02, 2011 8:48 am ] |
| Post subject: | ok thanks for the responses |
i have already pulled out the push button shift and add an additional cross member for the late model 904 to answer dan and what is it about the small converters i am still using that twists my input shafts in two or rips the front pump seals out that the later larger ones would be better. And my block is a 68 with the orginal 63 crank and rods in it Ooo and i have been using a reverse manual valve body with a B&M Z Gate shifter |
