| Help identifying this Tansmission https://slantsix.org/forum/viewtopic.php?t=45801 |
| Author: | Big T [ Mon Aug 01, 2011 8:50 pm ] |
| Post subject: | Help identifying this Tansmission |
Looks like a 904 pan, similar style but 14 bolts... If I looked correctly 904 has 11... 727 has 14 but is different style. Here is some pictures...along with a serial number on the side of the housing ... Drivers side... Thanks ![]() ![]()
| Author: | Mike'68Dart [ Mon Aug 01, 2011 8:56 pm ] |
This site says the 904 and others have 14 bolts with that pattern. I am still a newbie with this stuff...... http://transmissiontechnologies.com/chr ... hapes.aspx |
| Author: | Big T [ Mon Aug 01, 2011 9:03 pm ] |
This is was what I saw earlier today.. http://www.roadkillcustoms.com/hot-rods ... cation.asp Thank You |
| Author: | Joshie225 [ Mon Aug 01, 2011 9:15 pm ] |
I believe the 'baby' 904 Mitsubishi used might have only had 11 pan bolts. Your trans certainly looks like the standard A904. |
| Author: | Fopar [ Mon Aug 01, 2011 9:17 pm ] |
Terry the pans on mine all have 14 bolts. Richard |
| Author: | Big T [ Mon Aug 01, 2011 9:30 pm ] |
Thanks Josh & Fopar... I guess I will look at the one at the shop tomorrow and get on a better relationship.... If this is a good trans...should help save so money on the rebuild. Was told in neighborhood of $600ish...with out donor parts... FINGERS CROSSED!!!! Thanks again |
| Author: | Kidd [ Tue Aug 02, 2011 7:27 am ] |
