| 69 Dart engine wiring harness. https://slantsix.org/forum/viewtopic.php?t=45846 |
| Author: | raPoM [ Thu Aug 04, 2011 11:41 pm ] |
| Post subject: | 69 Dart engine wiring harness. |
Ok. So I bought the 69 dart and the engine wiring harness is trashed. Someone tried to swap in electronic ignition and failed. I am trying to decide if I should try and fix it using wire I have on hand or bite the bullet and go with the evans wiring engine harness. Anyone have any experiance with evans? Its 95 with points,and 105 with electronic ignition. I plan on running the GM HEI over the stock stuff that is sitting in there now,so if I go that route should I just buy the points harness? Thanks! |
| Author: | raPoM [ Sat Aug 06, 2011 8:12 am ] |
Anybody? Ok, does anyone know if I can use a harness out of another year a body? Thanks |
| Author: | SlantSixDan [ Sat Aug 06, 2011 8:24 am ] |
Definitely go with Evans. Very nice workmanship and reasonable pricing. |
| Author: | Rust collector [ Sat Aug 06, 2011 8:32 am ] |
For that price, I would get a new one. I would get a points one for hei... |
| Author: | raPoM [ Sat Aug 06, 2011 2:13 pm ] |
Thank you guys. Dan: you have used one of evans wiring systems before? I definitely trust your opinion,you know your electrical |
| Author: | raPoM [ Sat Aug 06, 2011 2:30 pm ] |
Also,does anyone know if a 70 dart uses the same harness as a 69,besides that it uses a plug for the electronic voltage regulator? |
