| 904 rebuild https://slantsix.org/forum/viewtopic.php?t=45852 |
| Author: | kielbasa [ Fri Aug 05, 2011 2:36 pm ] |
| Post subject: | 904 rebuild |
ive been looking into rebuilding it my self, but ive never done a trans before. i know the kit comes out to around 100 bucks. i thought id call my local trans shop, and they told me $1000 bucks to rebuild. thats 900 dollars in labor! fuuuck that |
| Author: | Rust collector [ Fri Aug 05, 2011 2:51 pm ] |
Go for it! the 904 is a very simple thing, just keep everything clean, and read the manual |
| Author: | kman [ Tue Aug 16, 2011 7:13 am ] |
| Post subject: | rebuild |
let me know how this goes, and take pictures. thanxs |
| Author: | bigslant6fan [ Wed Aug 17, 2011 5:59 pm ] |
| Post subject: | . |
I'd take apart,and put back together a junk 904 trans first,just so you can learn. |
| Author: | lancer61 [ Thu Aug 25, 2011 2:20 pm ] |
It's no big deal, very easy to work with, you would have good use of a slide hammer to get the oil pump out, the clutches can be done with a clamp and a piece of wood shaped like a U. If you do have an old 904 with rear oil pump it is a bit tricky to get that one aligned (the cover that is), it's a bit picky. A manual is good to have. |
