It is currently Sun May 24, 2026 5:08 pm
 Post subject: Brake bleeding help
PostPosted: Sat Aug 06, 2011 1:06 pm
The brake system is all drums, with a 71 or 72 dual master cylinder.
The right rear bled OK.
The left rear just keeps putting out a steady stream of bubbles.
Where are they coming from?
I swapped in a new left rear wheel cylinder, and it does the same thing.
How do I find the leak?
Is there a way one person can do it?
Been working on it a couple weeks...
I got air in the system when bleeding the left front.
I was using a little one-man bleeding kit.
One time, I got on the ground and closed the bleeder,
emptied the jar,
forgot to top-off the master cylinder,
got back in the seat,
and the pedal went to the floor.
That's when I started bleeding the rear brakes and ran into this problem.
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Sat Aug 06, 2011 1:53 pm
you need to bench bleed the m/c again, have someone pump the brakes while you crack the lines at the m/c--- get all the air out of there 1st-- then proceed with the rear most point.
If that doesn't work check your fittings closely== maybe a hairline crack in the lines , Lawrence
