It is currently Tue Oct 13, 2026 9:06 pm
PostPosted: Sat Oct 01, 2011 5:43 am
OK
its getting cool. choke is wired open
have Hooker headers
stock 2 barrel intake carb
our choke is currently wired open
so...
is the anyway to install a working choke
or do I need a manuel one
thank you cold weather peeps.
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Oct 01, 2011 8:46 am
More info, please. What kind of carburetor is this?
PostPosted: Sat Oct 01, 2011 8:54 am
stock 2 barrel holley/intake
off a 1978 dodge aspen
slant six's RULE!
PostPosted: Sat Oct 01, 2011 9:12 am
That's not quite a stock setup (carb is a Holley 2280; stock was Carter BBD) and that throttle/KD linkage is definitely not stock :shock: . It's going to be difficult to add a satisfactory manual choke conversion to that carburetor, but probably not impossible, and looks like you've had some experience fabricating linkage setups already on this car. How are your welding skills? You could weld a simple platform onto the applicable header runner to mount a #1232 Electric choke kit...
PostPosted: Sat Oct 01, 2011 10:22 am
On an unrelated note, wouldn't the missing EGR valve result in a massive vacumn leak?
Kevin :shrug:
crossthreads are better than locktite
PostPosted: Wed Oct 05, 2011 7:30 am
Kevin :shrug:
http://www.youtube.com/watch?v=tV6u97beANs
slant six's RULE!
Users browsing this forum: No registered users and 15 guests
