| Budget turbo build https://slantsix.org/forum/viewtopic.php?t=45921 |
| Author: | 64drtGt [ Thu Aug 11, 2011 6:44 pm ] |
| Post subject: | Budget turbo build |
i am thinking about turboing my dart and was wondering what I have in mind is a good idea or not. I have a 83 truck engine that seems to run good and doesnt smoke. I was thinking of having a cam reground by Oregon, have like five thousands taken of the head just to true it up and a new head gasket and head bolts. Is there any 2BBL carbs that would work with boost? I was thinking about a turbo off a supra as I can find them halfway easy and cheap. How would that work? I just want to run like 5-10 psi and play on the street and friday night street fights. |
| Author: | Dart270 [ Fri Aug 12, 2011 4:49 am ] |
bigslant6fan has used a BBD on his turbo setup previously. Holley 500 2bbl would probably work well too. Sounds like fun. A stock Buick GN turbo would be a good place to start too. Lou |
| Author: | raPoM [ Sat Aug 13, 2011 9:52 am ] |
My turbo plans would include a clifford 4bbl intake with the Holley 500 2bbl on top set up for boost,and a stock GN turbo with one of those cheap IC kits from ebay. I dont think you would NEED an IC for 5-10 lbs,but it will help. |
| Author: | 64drtGt [ Sat Aug 13, 2011 10:26 am ] |
L Quote: My turbo plans would include a clifford 4bbl intake with the Holley 500 2bbl on top set up for boost,and a stock GN turbo with one of those cheap IC kits from ebay. I dont think you would NEED an IC for 5-10 lbs,but it will help.
What would the 4bbl intake give me over a 2bbl intake? I was thinking why spend the extra money for a 4bbl intake if i was going to run a 2 bbl on it.
| Author: | raPoM [ Sat Aug 13, 2011 10:49 am ] |
I assume you mean over the cast iron super six intake?! Lightweight ,larger plenum area,and larger runners. |
| Author: | 64drtGt [ Sat Aug 13, 2011 11:20 am ] |
If i did find a clifford for a reasonable price i would just run a 600 holley 4bbl |
| Author: | raPoM [ Sat Aug 13, 2011 11:42 am ] |
Whatever works for you. I would stick with the 2bbl for ease of tuning,but thats me. |
