| what gaskets are these https://slantsix.org/forum/viewtopic.php?t=45922 |
| Author: | kielbasa [ Thu Aug 11, 2011 6:48 pm ] |
| Post subject: | what gaskets are these |
help would very much be appreciated
| Author: | SlantSixDan [ Thu Aug 11, 2011 7:24 pm ] |
1 and 2: probably oil pump cover O-rings 3 and 4 and 8: air cleaner to carburetor 5: EGR valve to intake manifold 6: ? 7: Air injection tube to cylinder head 9: Probably oil pump pressure regulator valve cap 10: There are two different distributor O-rings, are you sure this isn't one of them? |
| Author: | kielbasa [ Thu Aug 11, 2011 7:28 pm ] |
i suppose it could be the shaft o ring, didnt think about that. i dont think ill be using EGR, or air injection, there is a oil pressure regulator valve in the oil pump? my old worn out stock one has a sending unit, while my new one has a plug, i suppose i need to swich that out, is that what you talking about? thanks bud |
| Author: | 66aCUDA [ Fri Aug 12, 2011 6:35 am ] |
Yes Bud you shouldn't need the oil pump one as your new pump has a new ring in it. Frank |
