| convertors https://slantsix.org/forum/viewtopic.php?t=45932 |
| Author: | 63dartgt [ Fri Aug 12, 2011 5:43 pm ] |
| Post subject: | convertors |
In a previous insert i was told that i am twisting input shafts on the 904s in two because i am running the older smaller torque convertor. Why is this, what is the science or mechanics behind it?? |
| Author: | Dart270 [ Fri Aug 12, 2011 6:01 pm ] |
I think whoever told you that is full of it. I've never seen a twisted input shaft. However, a common failure w/ higher HP engines is that the pump drive hub on the converter can split or break off. That might be what they meant? Lou |
| Author: | Doc [ Fri Aug 12, 2011 6:02 pm ] |
The 60-67 904 (small hub) uses a smaller, 3/4 diameter input shaft w/ course splines. The 68 & later 904/998/999 (big hub) transmissions use a 7/8 diameter shaft w/ fine splines. You must have a pretty powerful SL6 to be breaking the input shaft off the trans. DD |
| Author: | 63dartgt [ Fri Aug 12, 2011 6:07 pm ] |
ya about 300 horse maybe if i am lucky quarters in the 11's when i get lucky usually 12-13's but i twist my input shafts in two or i will blow or suck the the front pump seals out in the tranny |
| Author: | slantzilla [ Fri Aug 12, 2011 7:40 pm ] |
Sounds to me like you need to have someone build your trans that knows what he is doing. Broken input is a sign of internal issues, not horsepower. Do you have tire screeching, neck snapping shifts? |
| Author: | Dart270 [ Sat Aug 13, 2011 7:12 am ] |
Where are you located? It might be nice for some of us to meet you and see your fast Slant 6. Or, you could come to a Slant 6 drag race? Lou |
