| Not a carb problem anymore but still runs like crap https://slantsix.org/forum/viewtopic.php?t=45945 |
| Author: | Ross [ Sat Aug 13, 2011 7:21 pm ] |
| Post subject: | Not a carb problem anymore but still runs like crap |
I got a 1920 from Seth, rebuilt it and adjusted to specs. New carb mount gasket as well. Got a new starter today so I could take it for a test drive. It still has the idle that you can tell is a vac leak. I sprayed starting fluid on intake to head, leak at cylinder #4. I don't have the money atm to get the gasket since it just went to a starter. So I put some jb stik on it. Was a lttle better. And yes I know before you scold me that jb stik is not the best solution but its the only thing I had. I will post a video at curb idle when I get on my computer. Also the other day it backfired at highway speed (65mph, 2800 rpm). What would cause that? Also any suggestions on a temp fix for the intake gasket or a good gasket set to buy would be helpful. Thanks Cody |
| Author: | Ross [ Sat Aug 13, 2011 8:33 pm ] |
here is a crappy cellphone vid. http://www.youtube.com/watch?v=WBB7MiD_usU |
